Pandora Tomorrow XBOX HELP
Discussion in 'Xbox Forums' started by Marc, Mar 18, 2005.
  1. Marc
    Marc
    Jul 8, 2004
    11,719
    Titchfield
    +1,101
    Could someone with the XBOX version of Pandora tomorrow find a couple of ini files on the hard drive from the install for me? I'm looking for splintercell2.ini and splintercell2user.ini
    failing that, default.ini and defaultuser.ini off the dvd would also be fine.
    The reason i need these, is that i have the PC version which has no option to configure a joypad, BUT you can configure one by manually entering the joypad controls into the ini file. I've already done it with just about all of them, but i can't figure out how to make Sam speed up or slow down depending on how far i push the analog stick, and i think looking at the xbox ones will help.
    thanks in advance
    Marc
