Panasonix TX-65HZ1000B VESA hole Top Offset
Andrewnw
Dear All,
Can you measure a Panasonic TX-65HZ1000B, or one of the series models, and tell me the measurement (in mm) of the top VESA holes from the top of the screen.
It is a VESA 400*400 hole pattern and the 65" model has a height of 837 mm.
The available Panasonic Technical Dimensions drawing does not show this measurement.
UK Panasonic Customer Support does not have this information !!!! I asked.
I have tried to guess it from a line drawing, as bottom of screen to VESA hole as 94mm, and top of screen to VESA hole as 343 mm.
I would like the actual distance confirmed before I drill five 10 mm holes in a plaster wall for the Wall Mount.
Regards Andrew
Gazgum
100mm from bottom bezel edge to lower fixing holes
: 12B6DC87-2189-4051-988A-CCC52E7C8051.jpeg
Thanks to a member in the HZ Owners Thread.
Andrewnw
Thank You for a quick and visual confirmation.
So the top VESA hole offset distance = 837 (height) - 400 (VESA) -100 (bottom offset) = 337 mm
Now I can drill for my Sanus VXF730-B2 wall mount.
Gazgum
You’re welcome! Recommend you do what I do and double check where bottom vesa screws will be on the tv mount before drilling ( and your tv bottom edge will be 100mm below this obviously!) Always do the double check is my point!👍
