Panasonix TH37PE50 wall mounting sizes
Discussion in 'Home Cinema Buying & Building' started by emjga, May 9, 2005.
  1. emjga
    emjga
    Dec 23, 2004
    41
    Folks
    I have just ordered a TH37PH50.
    It is going to be wall mounted , but in a alcove
    I have got on order one of RS100 brackets.
    RS100 Universal Plasma LCD TV Vari -TILT
    I know the size of the bracket is
    710 wide X 455 high mm
    Note it is a tilt bracket
    Can any body advise on distance of the bottom edge of the bracket
    to the bottom edge of the plasmer.
    So I can fix the bracket on to the wall , before the screen arrives.
    There is a shelf in the alcove , hence need to be able to clear that.
    Matt
