Panasoniv Nv-70hq
Discussion in 'Digital TV & Video Players & Recorders' started by cjpat55, Feb 12, 2002.
Tags:
  1. cjpat55
    cjpat55
    Nov 7, 2001
    5
    middlesbrough
    I have recently aquired one of these oldish machines. It seems to work ok with the only fault appearing to be a loudish sqeaking noise when the tape first starts up or when ff / rw is used. the sound dissapears almost at once. What and with what should I attempt to lubricate something with to eliminate the sound? also does this 'sound' serious?
    cjpat:confused:
  2. Garrett
    Garrett
    Apr 21, 2001
    43,187
    2
    167
    The best thief you'll never see.
    +8,151
    Great machine, I use to know of hand the part to oil (saw an engineer do it), but I only use the 70 as a back-up now and has not needed oiling for ages. If you do oil it, uses very thin oil, and very little.
    :cool: Ruby quartz shades.
  3. cjpat55
    cjpat55
    Nov 7, 2001
    5
    middlesbrough
    Hi Garrett
    How you remembered which part to oil?:confused:
    cjpat
  4. Garrett
    Garrett
    Apr 21, 2001
    43,187
    2
    167
    +8,151
    Hi cjpat55
    Is that ff when viewing? If it is I think it is in the wheel mechanisms on the RH side, just at the front of the, video cassette tray in the eject mode.
    Mine wasn’t a loudish squeak more a dry abrasive sound.
  5. cjpat55
    cjpat55
    Nov 7, 2001
    5
    middlesbrough
    Hi Garret
    Thanks for the reply....mine just gives a loudish groaning type sqeak for a few secs then it goes ok. I will investigate further , particularly the wheel mechanisms, when I have a min.
    cjpat
  6. gges
    gges
    I offered to help with this problem a while ago but forgot. Sorry! Easy cure - take the bottom off the VCR - put a tape in and press play. Look out for the capstan motor - spins quite slowly. You will see a brake on the rotor - the noise comes from the felt pad. Literally ONE DROP of oil on this pad will cure the fault. Do not be tempted to oil anything else!
    Rgds, GGES.
