Panasonice TH42PW7 - HDTV compatable?
Discussion in 'Panasonic TVs Forum' started by xander_rander, May 27, 2005.
  1. xander_rander
    xander_rander
    hey people, i have a panasonic TH42PW7 and was wondering if it can support HDTV? i think it can but not sure tho
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    nope, not without a scaler matie
  3. xander_rander
    xander_rander
    whats one of them dude?
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
  5. xander_rander
    xander_rander
    so with this thing i can get hdtv?
    thanks dude this is good info u gave me much appricated!
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    you can get hdtv, but it will be in SD resolution so theres not really much point, no real improvement in quality
  7. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    the pw7 can display HDTV out of the box, but it will scale it down to its native resolution. It will not display a fulll HDTV picture.
  8. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i think it will be a better pq than normal sky......but clearly a proper hdcp compliant screen is going to be best result. Xander, there is a forum for scalers and i suggest you look in there before shelling out your hard earned
  9. xander_rander
    xander_rander
    maybe i should of studied plasmas a bit more before shellin out the cash :( well thanks for the info everyone and cheers mep - i will look into the scaler before i do anything crazy ;)
  10. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    in the meantime the pw7 is a very good screen so just enjoy
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    as long as you dont try and feed it DVi/HDMI at 720p or 1080i @ 50Hz it will be fine
  12. oneline
    oneline
    Nov 3, 2002
    33
    St Helens
    Sorry to jump in guys,but are you saying the PW7 is not SKY HD compatible because of the resolution or is there some other problem with the DVI-HDCP board available with this screen.
    Keith
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,902
    The Borders
    +3,122
    Hello all
    Just for clarity!!!
    The TH-42PWD7 Display is capable of Inputting and Displaying various High Definition signals via RGBHV or YUV on Analogue (HD15 or 3BNC) and Digital (DVI or HDMI).
    As others have pointed out as this is a Standard Definition Display - any High Definition sources will be remapped to the Displays 852x480 pixel array. Which means you loose resolution - though you'll still 'know' your looking at HD as there's more to HD than just resolution.
    The 'Problem' with the 7 Series Displays for those looking to Input the HDCP encrypted signals that will be Output by a SKY HD Digibox being the lack of support for 720P or 1080i at 50 Hz.
    You can use a suitably equipped external video processor to convert 720P(50) and 1080i(50) signals to 720P(60) which the Display will work with - though you risk introducing some Frame Rate Judder in the conversion if you pick the wrong converter.
    Best regards
    Joe
