Panasonicd DMR-E55 - DVD Media question !!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Seanjackdan, Aug 18, 2004.
  1. Seanjackdan
    Seanjackdan
    I have ordered a DMR-E55 DVD recorder, and have 2 questions:
    1) Can this player record with DVD-RW, as well as DVD-R, and DVD-RAM ???
    2) Can you pause a recording, say for example you are taping some Music Videos from a Sky music channel, and you want to cut out the adverts in-between....
    Thanks.......
    Sean !!!!!!!
  2. monocrider
    monocrider
    Can't speak from personal experience, but I believe the answers are "No" and "Yes" respectively.
    Regards,
    John
  3. martin15
    martin15
    Aug 11, 2004
    Speaking from personal experience the answers are NO (only -R) and YES (press the pause button)
    regards
    Martin
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,599
    You can also use the Partial Erase function, i.e. you record the programme and then, after it's all done, you go back and chop out the bits you don't want. Ideal for music use as well is the Playlist function that allows you arrange music videos in the order you want.
  5. Seanjackdan
    Seanjackdan
    thanx for the replies - so if I want to use re-writable discs, I have to use DVD-RAM - is that correct...........
    Sean.................
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,599
    That is correct.
  7. apreading
    apreading
    Jun 28, 2004
    283
    +15
    Get them from 7dayshop.com - 5 packs of Panasonic DVD-RAM for £11.99. Best price for the best media IMHO.
  8. Seanjackdan
    Seanjackdan
    thanx everyone for all your help.........
    sean..........
  9. firstwave
    firstwave
    apreading: looking at the 7dayshop site, it appears the ram are non-cartridge type - are these correct for the DMR-E55, or would one need to buy a cartridge as well.
    Sorry if it's a silly question, but only just ordered my recorder so do not know what it uses yet.
    Darren
  10. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,599
    Panasonic DVD recorders take DVD-RAM caddied or non-caddied.
  11. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    Seanjackdan, I know you've ordered it but if you can stretch to the E85 you wont regret it. The hard disk makes such a difference whether recording, editing or archiving. All the hassle with finding blank disks, swapping every 2 or so hours, is it a DVD-R or DVD-RAM programme. Editing isn't seemless IMO and the cost of the more expensive additional RAM disks would go some way towards the extra cost of the E85. Owning both (unfortunately) I know the benefits are huge.
