Panasonic500 live pictures!!
Discussion in 'Plasma TVs' started by grasshopper519, May 31, 2005.
  1. grasshopper519
    grasshopper519
    I need live pictures of 500 42". Im chosing beetwen the 500 and PS42S5H. It would be great if someone could help me with this one! Maaany pictures! :thumbsup: Thanks!
  2. Stokesey
    Stokesey
    Send me ur email address and I will mail u pictures of my wall mounted 500.
  3. mugsy
    mugsy
    Nov 1, 2002
    668
    Kent
    +20
    Any chance of posting them here for all to see? :thumbsup:
  4. Stokesey
    Stokesey
    Happy to post up pictures............ if someone tells me how to do it!
    Thanks.
  5. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    You can either post images as attachments. Click on manage attachments under the submit reply button and follow the prompts. This method limits image size however.
    Another method is to host your images on the web say with your own ISP and then refer to them in your post with tags, e.g.
    [color=black][[/color]img]http://www.youraddress.co.uk/yourimage.jpg
    Hope that helps.
    S.
  6. Stokesey
    Stokesey
    Okay, I'm at work at the moment but will be home at midnight (ish), will post a couple of shots then.
    Thanks,
    Stuart.
  7. the highlander
    the highlander
    Mar 29, 2005
    160
    Bonnie Banks O' Loch Lomond
    or use THIS free hosting for images :thumbsup:
  8. Stokesey
    Stokesey
  9. xenole
    xenole
    Jan 2, 2005
    114
    That "brownish" bit at the bottom on the screen looks rather off putting......... (the bit with the logo etc).
  10. zAndy1
    zAndy1
    Nov 26, 2002
    19,386
    2
    5
    163
    +6,497
    Is that a rainbow over the track on the 2nd pic or solarisation?
  11. des_pd_ tdi
    des_pd_ tdi
    Apr 11, 2005
    71
  12. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
  13. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    There are a few cosmetic issues with the PV500, the silver bit being one. It's also pretty big. They have tried to disguise the size of the speakers by giving it a very wide black glass border inside the bezel, it's about 35mm all round, as opposed to about 15mm on the panel models. Add the thick bezel too, and it's pretty imposing! Be prepared, the overall dimensions are close to a PHD 50"!!
  14. Stokesey
    Stokesey
    The rainbow effect on the 2nd picture is just from using the flash, I'm thinking about dropping the plasma a few inches so that it virtually sits on top of the fireplace?
  15. fugsi
    fugsi
    Dec 10, 2004
    27
    i like it alot ... where is your wiring if you wall mounted i thought it connects direct to plasma unlike tunerbox
  16. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    STOKESEY, what size is your panny 32' or 37' can't seen to figure out ?
  17. xenole
    xenole
    Jan 2, 2005
    114
    He's probably got a plasterboard wall and is running the cabling behind that or through a cable slot cut into a brick wall............
    Going to be a load of cables with the Panasonic - i.e. tv ariel, Plasma power lead, couple of scarts or component, hdmi etc, so very visible if you don't do something like that (always best if you want a pro wall mounted look)
  18. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
    kumamoto, after reading some of Stokesey's other posts, it is a 42" PV500 in the photos.
    It does look smaller than that tho but I think that is because the black surround around the screen is quite big ? Maybe ?
    I have to admit, I did a search after I saw the photos to make sure what size it was.
    I need to see one in the 'flesh' without a doubt.
  19. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    thanks daipac, i have placed an order for the 37pv500 with hispek, expecting delivery next week.
    I was concern about the plasma being too masive as i don't want the tv to dominate one part of the living room, that why i went for a 37'
    Can anyone comment on pq when connected to sky ?
  20. Stokesey
    Stokesey
    It is a 42" plasma and all cables are run behind the plasterboard wall, was a nightmare to do especially as I needed to run: power, HDMI, scart, phono, component, aerial, pleased with the result though!! The picture via component (especially when playing something like Monsters Inc) is amazing, the colours are something else!! Also through Sky+ the picture is very good, nothing to what we can expect though when they launch the HD service! Still haven't set it all up properly yet as I just haven't had the time.
  21. steddyman
    steddyman
    Dec 25, 2004
    448
    +13
    I can't get to any of those images you linked :(
    Oh well, I guess that saves me a few grand.
    Steddy
  22. tim k
    tim k
    For one of the best spec plasmas around it looks pretty cack wall mounted doesnt it? that silver rim at the bottom looks like a plastic addon that would snap off with a small tug. Not a patch on the aesthetics of hitachis hd 42", or sammys sp50 dlp. although i do like the viera cabinet, but still nowhere near enough room on that for amp, sky, gaming, dvd player, recorder etc etc.
  23. alliwant
    alliwant
    i think it looks cracking...saving my pennies as we speak, although we will prob be on 13th gen plasma's by then!! :(
  24. Taz69
    Taz69
    Apr 15, 2002
    2,324
    Bristol
    +54
    is there any problems with mounting a plasma above a fireplace, even if you use the fire, lol
    Just a I see a lot of people have done this, I am about to, but want to make sure there will be no problems with rising heat.
    Taz
  25. Stokesey
    Stokesey
    Tim K, thanks for your kind words!!
    LOL......
  26. tim k
    tim k
    no, i didnt mean to be so abrupt, (hard day at work followed by dentist please forgive!!). I would love one of the pv500's for its capability, but im just not taken by the silver rim, i think it would have looked nicer to stay in black and maybe the phd8 will be more up my street. but you have done a lovely job of concealing your wires, i know with my ex pw6 setup how hard it is.
  27. Lethal Lee
    Lethal Lee
    Aug 15, 2003
    334
    Southwick, Brighton
    +12
    I had a look at one of these (42") very quickly today. A Layer Cake DVD via HDMI did lok very nice!!
    However I agree with others it did look quite big, and it seemed to be quite a chunky depth to it to, the sales guy measured it at 10cm.
    What I really want to know, with any pictures if available too, is what is the depth once it is on the wall bracket, ie how far from the wall to the front of the screen, as the one I saw was just on the floor in the polystyrene because they hadnt had time to get it out properly and set it up. Again, the guy in the shop I was in, said he thought it would be 6-7" which seems a huge distance jutting out from the wall. What do people who have this plasma wall mounted think? Can anyone who has one help?
    Lee
  28. fdj
    fdj
    we are looking for some advice on the size and practibility of the panasonics. What sort of distance can you watch the 42" set from? We have a room where we would sit between 3 and 5 meters away. Would this be far enough away? Would a 37" set be better.
    Bear in mind that we have 2 kids so the room is for the whole family, not just for watching tv.
    Thanks in advance.
    PS where can we see these beasts in the flesh?
    fdj :lease:
  29. Taz69
    Taz69
    Apr 15, 2002
    2,324
    Bristol
    +54
    anyone please.
    Taz
  30. xenole
    xenole
    Jan 2, 2005
    114
    My local Dixons in Grimsby has one in, so I would assume Currys probably would if you want to view. My local Panasonic dealer has them in too......goin to have a good look on Saturday, but I'm more swayed towards waiting for the commercial screen as they do seem a bit bulky for wall mounting.
    You probably need to find a decent dealer to see one though as we all know the lousy inputs high street stores such as Dixons generally have.
