Panasonic XR70 BESt Price???????/
Discussion in 'AV Receivers & Amplifiers' started by DLPGirl, Apr 14, 2005.
  1. DLPGirl
    DLPGirl
    I have been offered XR70 brand new delivered for £288.00 Is this a good price?
    Can it be had for less if i get it from the US? Any complications??
  2. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    Price is the same as on price runner so it probably isnt bad. A while of search the net may throw up something a little cheaper but it is a case of time -v- savings.
    It may be possible to buy from the US but remember to add on the cost of import duty & VAT and the cost of buying a power transformer for it which can be costly. The other complication is (a) if you have to return it (b) your warrenty may not be valid in the UK
  3. DLPGirl
    DLPGirl
    Interestingly it isnt cheaper to import this reciever from germany. It is infact £312 plus the cost of postage. For once no rip off briton!!!!
  4. DLPGirl
    DLPGirl
    Does anybody own this amp? what do they think of it?
  5. AGroucutt
    AGroucutt
    Dec 31, 2004
    74
    Birmingham,UK
    I own this Amp does the job for me anyway? Any Questions?
