Panasonic XR10 Connections problem
S
staffspeted
**Newbie help!!**
I HAVE JUST PURCHASED A PANOSONIC XR HOME CINEMA SYSTEM WITH THE SA-XR10 RECEIVER.HOWEVER I HAVE HIT A SNAG, THIS HAS 3 AUDIO INPUTS (2 OPTICAL,1 COAXIAL). IS THERE ANY WAY I CAN CONNECT 4 PIECES OF EQUIPMENT TO IT?
1 X DVD
1 X SKY RECEIVER
1 X VIDEO
1 X DIGITAL MOTORISED SATELLITE RECEIVER
CAN ONE CABLE BE SPLIT TO CARRY 2 INPUTS INTO THE XR10 OR WILL I HAVE TO CONNECT ONE OF MY ITEMS TO THE TV VIA PHONO OR SCART FOR SOUND?
HELP MUCH APPRECIATED, p.dewing
Ian J
The DVD player should be plugged into either the co-axial or optical digital connector but additionally there are two more pairs of analogue phono sockets. The Sky box would plug into one and the VCR into the other.
These connections will give you sound only and you will have to connect each source directly to the TV for picture.
That leaves you with one left over unless either of your digiboxes has a digital audio output.
S
staffspeted
Thanks for your reply Ian. So you mean loop the Video and Skybox thru the DVD Player?
Ian J
If you have analogue outputs on your TV you can connect up the Digibox & VCR by scart with the sound coming back out from the TV into your amp from the phono sockets.
If both your DVD and TV have component connectors I would use those for the best quality picture wiith the DVD connected to the amp via a digital connection
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
