Panasonic Wall Mount
Discussion in 'Home Cinema Buying & Building' started by johnnyrockts, Aug 25, 2004.
  1. johnnyrockts
    johnnyrockts
    Please forgive me if this topic has been beaten to death, but i'm interested in mounting my Panasonic 42 inch plasma to the wall (TH-42PA20)...I'd prefer to purchase a wall mount made by panasonic, the only problem is that their site is very vague as to explaining which TVs will work with which mounts. I'm basically looking at these two;
    http://www.etronics.com/product.asp?icatid=4600&stk_code=pantywk42pr1u&svbname=403
    http://www.etronics.com/product.asp?icatid=4600&stk_code=pantywk42pr2u&svbname=403
    It looks like the cheaper one allows me to tilt the TV...is this the case? if so why is it cheaper? Basically i just want to know if they're compatible with my TH-42PA20.
    thanks for reading this,
    john
