Panasonic W/S Tv Query
Discussion in 'General TV Discussions Forum' started by waddell28, Feb 3, 2003.
Tags:
  1. waddell28
    waddell28
    I have a Panasonic TX32PK3. Noticed that if theres any white writing on screen, subtitles etc, theres a blue & red 'shadow' behind it. Also happens on the TV's menus.
    Is this a major problem or can I fix it?
    Also sometimes notice a green edging around objects/ people etc on screen, this happens on the normal channels & the digital/DVD scart channels. Its under guarantee, wonder if I should be calling out an engineer.
    Any input would be grateful
  2. shaunthedude
    shaunthedude
    sounds like the convergence is out. Call for an engineer for a fix
    hth
    shaun
