Panasonic VW-BN1 Burner
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by WarPig843, Feb 8, 2009.
  1. WarPig843
    WarPig843
    Oct 21, 2004
    304
    +19
    I purchased one of these the other day for my SD9 and burnt my first disc last night.
    Its a good piece of kit, just need to insert a dvd, plug it into a power socket, plug the SD9 into a socket, connect the two together with the supplied cable, press a button, and its done!
    And the dvd plays in HD on my PS3. :thumbsup:
    Obviously this just does a straight transfer from the SD card to a DVD and doesn't allow any editing. But if thats all you need (like me) then it does the job extremely easily.
    I know this wont be everyones choice, but my laptop isnt powerful to do any burning to dvd, so this unit suits me fine.
  2. john o
    john o
    Feb 25, 2006
    75
    May I ask where you brought it from and how much you payed, I am thinking about getting one for my SD9 when I return from my hols. cheers
  3. john o
    john o
    Feb 25, 2006
    75
    another quick question, is it true if you don`t have a blu ray player or ps3 you can`t play the discs in a normal dvd player ?
  4. WarPig843
    WarPig843
    Oct 21, 2004
    304
    +19
    I bought it from Panasonics E-Shop
    Panasonic : VW-BN1E-S
    It was £127 + £4 delivery.
    Ive seen them a bit cheaper on lesser known websites but I opted for Panasonic shop as they seem a more trustworthy supplier.
    As for playback on an SD dvd player, Im not sure to be honest. The disc wouldnt play on my laptop but I havent tried it on my SD dvd player. I would assume that it will only play back on a blu-ray player though. If you want to know for sure, I can try it on my SD player if you are thinking of buying it.
  5. ntm1275
    ntm1275
    Nov 18, 2005
    586
    43
    +132
    As far as I know, it burns using the BluRay file format, so a BluRay Player or PS3 would be needed
    Because AVCHD is based on the same format as BluRay, I think it just copies to whole file structure to a DVD blank, so a DVD player wouldn't be able to read the file structure
