Panasonic VT65 x.v.color problem
Discussion in 'Panasonic TVs Forum' started by JonnyP24, Feb 14, 2014.
  1. JonnyP24
    JonnyP24
    Jan 28, 2009
    130
    Manchester
    +8
    Hello all,
    I am having a really annoying problem with my VT65 and wondering if anyone could help?
    Basically, when watching some films a popup keeps popping up in the top left corner of the screen. It displays what hdmi channel it is on and also something called x.v.color. The screen flicks black for a second and then the popup is displayed. This happens randomly and makes films unwatchable.
    It only seems to happen on new blurays. So far 'This is the end' and 'Elysium'. Anyone have any ideas what this could be and how to fix it? I have searched through all the menu options and can't find anywhere that references x.v.color to turn it off. Why do some films have it and some don't?
    Any help would be much appreciated.
  2. matt1965
    matt1965
    Feb 14, 2014
    3
    hi mate i read somewere that if you use the self test option then switch off on the tv it clears this. worth a try.
  3. JonnyP24
    JonnyP24
    Jan 28, 2009
    130
    Manchester
    +8
    Hi mate. Cheers for the help. Any ideas where the self test option is? cheers
  4. matt1965
    matt1965
    Feb 14, 2014
    3
    Its in the help section.
  5. xit2050
    xit2050
    Aug 20, 2006
    4,917
    Belgium
    +509
    Set "contents type flag" to "off" in the set up menu of your blu-ray player.
  6. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    So why turn off and not enjoy the x.v.colour if it's available?
  7. xit2050
    xit2050
    Aug 20, 2006
    4,917
    Belgium
    +509
    The image transmitted is still the same, it just removes the pop up messages.
  8. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    I understand that, the OP seemed to want to disable it completely as a feature probably not understanding it's a benefit...I just commented generally :)
  9. JonnyP24
    JonnyP24
    Jan 28, 2009
    130
    Manchester
    +8
    Thanks for the reply. I turned contents flag off but it is still doing it :(
  10. JonnyP24
    JonnyP24
    Jan 28, 2009
    130
    Manchester
    +8
    Any other ideas chaps? Would massively appreciate any suggestions :)
  11. Tony Woodison
    Tony Woodison
    Feb 18, 2014
    16
    4
    Wiltshire
    I have the same problem with the VT55 set but I have experienced it only when playing Sony Blu-ray discs (Elysium and Captain Phillips). I have tried contacting Panasonic and so far they have not given me a solution. Really annoying.
  12. JonnyP24
    JonnyP24
    Jan 28, 2009
    130
    Manchester
    +8
    That is so odd. This is the End is also Sony. I'll try After Earth which I believe is Sony and report back.
  13. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    It's only Sony that releases x.v.colour discs AFAIK...do both of you have a panasonic BD player?
  14. Tony Woodison
    Tony Woodison
    Feb 18, 2014
    16
    4
    Wiltshire
    Yes, I have the Panasonic DMP-BDT330 Bluray player. Is this a contributing factor?
  15. JonnyP24
    JonnyP24
    Jan 28, 2009
    130
    Manchester
    +8
    Yes, I have a Panny DMP-BDT230
  16. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    From memory, watching the only x.v.colour disc I own doesn't act up as you describe, and that's from a Philips BD player to ST60 so perhaps it's a specific player/brand issue...suppose you can't borrow a different player?
  17. JonnyP24
    JonnyP24
    Jan 28, 2009
    130
    Manchester
    +8
    I have an old Panny player in the loft (I can't remember the model). I have never had an issue with that so I will try it tonight with a selection of problematic disks and report back. Cheers
  18. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    How exactly is x.v. colour different to normal colour? :confused: lol
  19. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    It has a larger gamut as an extension to standard HD rec.709 specification...it is not the same as forcing/expanding the normal HD colorspace into a display's wide gamut...
  20. gibbsy
    gibbsy
    May 17, 2007
    13,549
    3
    Cwm Cynon, De Cymru
    +7,572
    Watched Captain Phillips with nothing popping up. Fantastic PQ on the blu ray disc. My player is a Denon DBP-2012.
  21. Tony Woodison
    Tony Woodison
    Feb 18, 2014
    16
    4
    Wiltshire
    I don't know how to resolve this. I have had extensive email exchanges with panasonic but they don't seem to recognise the issue let alone address it! Is there not a technician out there that could come up with the answer?
  22. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    I need to take some time to translate that into words I can understand :laugh: LoL
  23. Gawaind1
    Gawaind1
    May 18, 2014
    3
    Hi mate, I'm sorry to bring up this old thread again, but I've been experiencing the same problem, , I've got a Panasonic zt65b and a Panasonic 3d bluray player, I was wondering if you have resolved the problem yet, ? I'd love to know if you can help. I'm getting pop up box constantly when I'm watching elysium mastered in 4k blu ray. Pop up says 1080 p 60hz xv colour. So annoying.
  24. Tony Woodison
    Tony Woodison
    Feb 18, 2014
    16
    4
    Wiltshire
    Hi Gawaind1. I wish I had resolved this issue but despite my best efforts I am still experiencing the problem. Panasonic have been singularly unhelpful (they don't seem to want to recognise the issue) and no one on the forum was able to help. I had hoped the latest Panasonic player firmware update resolved the issue but it didn't. I hope you have better luck getting the problem resolved as there must be a solution, and if you do I would be grateful if you would let me know because the pop up box is certainly spoiling my viewing of these Sony discs. Sorry I could not be of help.
  25. Gawaind1
    Gawaind1
    May 18, 2014
    3
    thank you for your reply it's very kind of you to take the time. It's just so strange, I gave the elysium mastered in 4k disc to a friend last night to try it on his Sony bluray player and he informed me it worked fine, ( his Sony bluray player incidentally isn't even 3d and years old) , this probably means that at least we can console ourselves in the fact that it's not our Panasonic tvs (well I hope not) it's probably a firmware bug in the panasonic blu ray player. Incidentally the panasonic bluray player I have is the panasonic BDP 130 . I'll keep looking for how we can resolve this issue and I will let you know if I find any answers, It only happened to me last night when I watched, mastered in 4k elysium, , the worrying thing is, is that all new bluray discs coming out will be mastered from 4k, so maybe the only answer is to get a Sony bluray player which I am considering, but I'll try and fix it first it's so annoying it's obviously a bug. Thank you for your time and it's also interesting to know that you tried Panasonic and they had no answers, they're bloody unless, thanks again kind regards Gawain
  26. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,306
    116
    Ashingdon
    +534
    If you change the VT's colour gamut to native (picture>advanced) does this help at all?
  27. Gawaind1
    Gawaind1
    May 18, 2014
    3
    I tried this already, I changed the colour from rec709 to naitive and it made no difference, I'm hoping the problem I down to my Panasonic bluray player and not the TV, I just spent 2,500 on a Panasonic ZT65b, so I pray it's the bluray player.
  28. MAX1210
    MAX1210
    Mar 9, 2009
    4,525
    3
    +1,239
    For those of you with Panasonic BluRay players - does switching "Deep Colour Output" to OFF on the player help? - found in HDMI output normally.
    Edit: When I brought my own copies of Elysium & Captain Philips into the store, the same thing happened on a new BDT460 & 65AX802. Sadly, I don't have my films here today to test.
  29. Gawaind1
    Gawaind1
    May 18, 2014
    3
    I need to get elysium back from. My friend who tested it on his Sony BLURAY player, who said he had no problems , when I get it back this afternoon I'll try turning the colour gourmet off to see if it helps and I'll get back to you later, it's annoying Panasonic are not even doing anything about it.
    I wonder if it's the Panasonic players incompatibility with the colour xv format ,
  30. saarnold
    saarnold
    Jun 17, 2008
    846
    LEEDS
    +347
    I have the 50VT65 and ZT65 tv's with the Panasonic BD500 and BD310 with no issues watching Elysium, Captain Philips, Total Recall or Amazing Spiderman so its not all panasonic BD players.
    Try speaking to a local Panasonic dealer to see if they can help - they are normally more knowledgeable that the big retail stores and are more willing to help - before i brought the ZT from TPS i spend quite some time on the phone discussing certain issues with plasma/led tv's on many occasions, without the pressure to buy.
    Hope you get it sorted:smashin:
    saarnold
