Panasonic VT50 flashing red light.
Discussion in 'Panasonic TVs Forum' started by bobbaray, Aug 29, 2013.
  1. bobbaray
    bobbaray
    Dec 13, 2005
    281
    2
    Leamington Spa
    +18
    Afternoon,
    Has anybody had this problem with their TV? Standby light flashes continuously and TV does not turn on. TV is under warranty, I was wondering if there was a quick fix.
  2. MAX1210
    MAX1210
    Mar 9, 2009
    4,525
    3
    +1,239
    Is it constant with a 4-sec interval, or is it a few times, then pauses then flashes again?
    BTW if the power LED is flashing, it's normally a service centre job.
  3. bobbaray
    bobbaray
    Dec 13, 2005
    281
    2
    Leamington Spa
    +18
    it flashes few times, then pauses then flashes again -
  4. MAX1210
    MAX1210
    Mar 9, 2009
    4,525
    3
    +1,239
    Depends on how many times, attached is the "blinking chart" an engineer would use. You'll need to contact your dealer/nearest approved service centre to arrange an engineer visit/collection of TV to service centre.
  5. bobbaray
    bobbaray
    Dec 13, 2005
    281
    2
    Leamington Spa
    +18
    Excellent,
    Thanks for your Help Max.
    I will contact the service centre
    Much appreciated
    Bobby
