Panasonic Viera
Discussion in 'Panasonic TVs Forum' started by olegna, Apr 14, 2005.
  1. olegna
    olegna
    Hi, new to this forums. Can somebody help? What would u say the best picture settings are to view standard TV? I mean Sky+ and Sky Italia. Whilst I thoroughly enjoy the excellent picture quality via my Denon AV, I cannot say the same with TV channels. I know that contrast and brightness play an important part...pls help!!! Thanx :cool:
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    u need to calibrate with a dvd. all THX dvd's have video test patterns on them.
    some i know of:
    star wars
    finding nemo
    terminator 2
  3. olegna
    olegna
    thx mate will try
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,827
    Galactica C.I.C.
    +272
    also adjust the settings in cinema mode and use this mode to view all of your programinng and dvds ect. Cinema mode gives the best alround performance once it has been adjusted useing Digital Video Essentials.
  6. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    i've read/heard about the DVE disc but gather that its not the easiest thing to use - and i'm not exactly technical
    SO
    does anybody have the disc and a viera (so they know the model in question to do the adjustments) who would like to come and see me and run through the whole thing??
    i'm in notts and you would be suitably rewarded :D
    if you've not got the disc but know how to use it i can buy one beforehand!
  7. olegna
    olegna
    so if i have understood correctly, i should first install the DVE software via my Denon AV? and then adjust the settings on "cinema" mode. This may sound like a silly question. What is the actual effect of DVE on digital TV source???
  8. Mep
    Mep
    Dec 25, 2004
    9,604
    Surrey
    +477
    dve isn't something you install....it's a dvd with calibration screens that you are meant to use to adjust your settings...but it is not easy to use ...i gave up on it becuase the guys voice is so bloody annoying :)
  9. olegna
    olegna
    thks mep, what is difference between THX and DVE pls?
    thks
  10. Timmy C
    Timmy C
    Oct 10, 2003
    4,894
    +320
    I may be missing something here but if you use the DVE dvd (or THX set up patterns) to set up your display then surely that's just going to set it up for dvd viewing and I think Olegna wants to set it up for Sky viewing. I don't have a plasma yet but I know with my projector the settings for DVD and Sky are very different!
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    mep the mute button doesnt effect PQ.........
    ideally you need a TPG that will feed sat boxes with a TPG (test patern generator) more possible is a TPG with scart output.....GOod TPG are several thousand pounds and need almost the same amount of money to able to use them, thats where your local ISF tech comes in, £250-£300 they come equipped and trained to do all of that and will calibrate for each source individually....however the veira is a real pain to do as it has 2 chassis (far from ideal) but your local tech may be able to do basic set-up for £100 taht is sufficient
  12. Mep
    Mep
    Dec 25, 2004
    9,604
    Surrey
    +477
    :D very funny mate!...actually i found the whole thing very annoying...aprt from teh big dipper ride and teh space shuttle :)
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    you mean you werent rivetted by the guy talking about cars????? i watch that daily for an eye opener......
  14. Mep
    Mep
    Dec 25, 2004
    9,604
    Surrey
    +477
    i never even got that far.......i'm probabaly to impatient...i just want to jump in and get tweaking
