Panasonic Viera with little clip on things
Discussion in 'Plasma TVs' started by Bluenose1878, Oct 30, 2004.
  1. Bluenose1878
    Bluenose1878
    I've just had my new Viera delivered (& love it) but in the box was a bag full of plastic cylinders sliced along the side to open them up with a magnet in them i think!? Might be a stupid question but what do i do with them, there's not much in the manual other than how to fit them, not where?? I'm guessing they are to fit on leads because there's already one on the power lead but which ones and what are they for?? Thanks...
  2. newcomer
    newcomer
    they fit onto S-VIDEO and VIDEO leadsand onto PC lead connections
  3. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    i dont think they are for pc svideo etc.
    ,ore like for interferance so im gona put mine ao all the power leads i think
  4. newcomer
    newcomer
    i have panny TH-42PA20 and it clearly shows them on these leads in fact it should be on headphones as well (small ones as they come in two sizes)
  5. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    AHH ok ,but what are they
  6. newcomer
    newcomer
    not sure but i suspect the are some sort of shielding??
  7. alan8477
    alan8477
    Dec 17, 2001
    574
    Pershore
    +5
    From my HiFi days I think they are ferrite rings designed to prevent interference (buzz and hum) induced through cables connected to the Viera. I have used all of them on my Viera connectors.
  8. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
  9. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    How rude There not in the manual,if they were dont you think we would know,thats why were asking the helpful people on this forum :)
  10. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I'm not rude,they're in my manual. And the set up sheet. :hiya:
  11. Bluenose1878
    Bluenose1878
    IT DOESN'T SHOW YOU WHERE THEY GO IN THE MANUAL OTHERWISE I WOULDN'T BE ASKING WOULD I??? IT SHOWS YOU HOW TO FIT THEM NOT WHERE!!!
  12. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    :oops: :oops: I do apologize happyh ,i should have looked harder,before going off on one, bad habit of mine,take care :smashin:
  13. Andy C
    Andy C
    Jul 14, 2004
    110
    16
    It doesn't say in the manual what they're for either.. as in why you should use them. My guess was for shielding also. Don't think I'll be able to get them on my IXOS flat SCARTs though. ;)
  14. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    No probs.
    Did you see my reply to your query regards E55 sound synch?
    It got it sorted for me.
  15. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    Hi happyh just looked and have set mine up similar to yours and sound is now fine,
    Its a shame sky + second scart isnt rgb,
  16. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Brackenlamb,
    still think you should try to get a digital sound connection from sky+ to amp.
    Some of the movies are 5.1 sound. I can't do that with my old skybox.
  17. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    i think ive done everything correctly
    sky+
    has rgb scart (no sound) going to tv
    fully wired scart going to dvd recorder
    phonos going to amp
    optical out going to amp
    dvd recorder
    scart from sky +
    component going to tv
    tv
    rgb scart (no sound ) from sky +
    component from dvd recorder
  18. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
  19. Krance
    Krance
    I can only assume if you have no problems then don't use them... if you are getting interference or hum then try placing these by the end of the cables....
    I also assume it's better to try and keep power cables away from signal cables anyway (any hi-fi mag or expert will tell you to keep these apart as much as possible)... and I think I even read that you should cross them at 90 if they need to cross (but not sure why so don't shoot me)
  20. hullupelle
    hullupelle
    I seem to remember from A level physics, a while ago mind you, that electromagnetic waves are generated around the cables (like a coil around cable) so by crossing 90 degrees the two electromagnetic waves are not intensified and coiling in the same direction.
