hi i have a panasonic viera txp42x10b tv but i cant find the best pitcher qaulaty can anyone help?
U uma09 Standard Member Jan 25, 2010 #1 hi i have a panasonic viera txp42x10b tv but i cant find the best pitcher qaulaty can anyone help?
F Fatwaz Guest Jan 26, 2010 #3 lots of people settings in the x10 owners thread,have a search in there but basically set it how you like it
B bighfishing Prominent Member Jan 26, 2010 #4 the out of the box settings on the x10 are very good, you should only have to tweak them slightly to suit your taste.
F Fatwaz Guest Jan 26, 2010 #6 then i suggest get a test disc like dve and set brightness and contrast to your room and lighting
B bighfishing Prominent Member Jan 26, 2010 #7 uma09 said: there not tht good pitcher allways dark and haysy. Click to expand... i think yours must be faulty then.
U uma09 Standard Member Jan 27, 2010 #8 has anyone one got any photos of there setting so i can put mines to the same ?
iybyisyl Established Member Jan 27, 2010 #9 Panasonic TX-P42X10 Plasma HDTV Review at AVForums.com Settings on here
