panasonic viera sd card problem
Discussion in 'Panasonic TVs Forum' started by avcar, Oct 24, 2004.
  1. avcar
    avcar
    Jul 14, 2004
    286
    +10
    hi all can anyone help me. im having trouble trying to view pictures from sd card , i have downloaded from my pc, i have formatted SD card to FAT also tried FAT32 in the manual it says to format to FAT12 or 16 which i dont have the option on my pc , the brand of sd card is VIKING .
    please help thanks
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Have you just copied the jpeg's over to your SD CARD from your PC? If you have you need to keep the standard directory structure that a digital camera would use...
    I guess to be more accurate I should have said that my images were in a directory called 'DCIM/100_NIKON'.
    This issue has been asked about before:
    http://www.avforums.com/forums/showthread.php?t=149175&highlight=jpeg
    http://www.avforums.com/forums/showthread.php?t=150561&highlight=format
    S.
  3. avcar
    avcar
    Jul 14, 2004
    286
    +10
    thanks for quick reply
    pics from sony memory stick copied to pc then d/loaded onto sd card
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    No problemo :) Hope you get it sorted. :) If you copy the Sony memory stick's folder / directory structure too then I imagine it should work. BTW if you get a PCMCIA / memory stick adaptor your telly would be able to read the memory sticks directly. I'm guessing an SD card is alot cheaper than the PCMCIA converter though ;)
    S.
  5. avcar
    avcar
    Jul 14, 2004
    286
    +10
    ive actually ordered a pc card out of stock been waiting for it for ages could not wait anymore,
    so ordered a sd card from ebuyer a viking 256mb for around 17.99 quite good price i think.
    so if ive already downloaded onto pc, do i just make any folder up and name -+100_pana ?? and drag my pics into that folder? :confused:
    is there an idiots guide any where?
    thnx
  6. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    On the SD Card, create a primary folder (i.e. from root) called DCIM.
    Then create a sub-folder in DCIM called 100_SONY.
    Place your jpeg images in the folder /DCIM/100_SONY.
    Hopefully then your Viera should be able to display the images.
    S.
  7. avcar
    avcar
    Jul 14, 2004
    286
    +10
    IT WORKS!!!!!!!!!
    for all others who have sony camera subfolder should be 101MSDCF (MS must stand for Memory Stick) dont know about dcf as my camera is dsc?
    steve i have a painstaking task of now renaming all my pictures DSC00001.JPG etc..
    yipee :thumbsup: :smoke:
  8. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    :cool: :clap: Nice one!
    Good to hear it's all sorted. :smashin:
    S.
  9. Red-Arrow7
    Red-Arrow7
    Hi, in Steve Ps earlier reply he suggested a Memory stick/PCMCIA adapter.
    I have bought a SANDISK 6 in 1 adapter and when the stick inserted straight from the camera it says "This file type is not supported"
    Any ideas please??!
    many thanks
  10. blindlemon
    blindlemon
    The PCMCIA slot also doesn't support CF type II - eg. Microdrives, either :(
  11. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Hi to quote myself from the original thread...
    I can only assume either one of two are possible reasons why you can't read your memory stick...
    1. The TV is not compatible with the multicard adaptor that you have bought.
    or,
    2. Is your camera saving images as 'EXIF standard JPEG images' that are sized between 64x64 to 8192x8192 pixels. I know some cameras can save images as a raw format so that minimises any possible compression issues associated with saving in the jpeg format.
    S.
  12. chan1490
    chan1490
    Does anyone know all of the supported file types?
    What about movie files from my computer such as MP4 or WMV or MPG or AVI?
  13. chan1490
    chan1490
    Never mind.
    I emailed Concierge and they only say that it can view unmodified jpg files.
