Panasonic Viera - PC Gaming
davegtt
Hello again people. had a thought today, I can connect my PC to the Viera but not given it much thought until today BUT would I be able to use it for gaming? I play Counterstrike Source and wouldnt mind giving it a shot... I know TFT screens have a delay on them, anything over 17ms IIRC is of no use for gaming, just wondered how the Viera would cope, anyone get any experience of gaming with it?
TIA
Dave
hornydragon
should be fine mate give it a go use a screen res of 1280x720 or similar and ket panel downscale can try 852x480 but i think 720ish will look and play better.
davegtt
right then, might give ti a crack. 1 last question then for any1 in the know with NTL. I have 2 different cables coming intot he house 1 running upstairs for the PC broadband and 1 coming straight into the front room for the TV. will I be able to unplug the TV and take the modem downstairs and use that cable? I can see that being my only downfall now as the cable upstairs wont be long enough to run all the way to the front room :) should be a top crack if I get it working. will report back with any findings. might do it when I get back from work. dunno got no heating downstairs so might be a tad cold until the weekend when the new radiators arrive.
geeWcee
Wear a woolly jumper and gloves and get cracking :D
M
MilesR
I've been seeing the specs on these plasmas and thinking that the max resolution would be 842x480 for a PC connection...given your comment hornydragon am I mistaken?! If so, then that really helps my decision making for a new TV :):)
Kwozzii
I plug a Sony Vaio laptop into mine with a res of 800x600 (laptop) and it looks great.....
Kwozzii
hornydragon
plasma will accept resolutions much higher than the native pixel array and do a pretty good job with them....
MAW
1280/720 goes particularly well as it's a 16:9 ratio, and often favoured by internal scaling software as it's also a yank HDTV resolution, at 60Hz. well worth trying, it looks excellent on PW7, PHD7, so why not the viera.
