Panasonic Viera - Cannot clear external connection indicator off screen.
Discussion in 'Panasonic TVs Forum' started by Steviebell, Jan 31, 2009.
  1. Steviebell
    Steviebell
    When watching a DVD (connected via Scart) there is a permanent indicator upper left of the screen saying "EC 1" in white writing. Is there any way I can clear it?:lease:
  2. alsina
    alsina
    Nov 30, 2008
    3,796
    +605
    Have you tried pressing the 'i' button on the tv remote. If this doesn't work, it sounds like a dodgy scart cable. Try wiggling the scart connectors and see if it clears.
  3. Steviebell
    Steviebell
    Good advice - I had been using a third party multi-machine remote without an "i" button. Thanks - all sorted now.
