Panasonic viera 42pe30b
Discussion in 'Plasma TVs' started by gerry42, Jan 8, 2005.
  1. gerry42
    gerry42
    Having an issue with picture quality on this set. Has been highly recommended on most Magazines, however seeing ghosting and faint cross screen graphics on Telewest. also picture quality of video recorder is crap.
    Any suggestions? Does the pixel config. at 850x 480 for this set provide a worse picture?
    Gerry
  2. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I have the same set and PQ is lovely on sky, dvd and freeview. Don't have a vcr though.
    It really does dedend on the source signal and how the connections are made.
    Can you give more info?
  3. shyewei
    shyewei
    Dec 11, 2002
    4,784
    London
    +147
    I recently acquired the 37" version and must say that I shared your reservations initially.
    Firstly ensure that your box is set to output RGB (the first time I have noticed a difference between settings) and secondly the picture seems to improve over time. I initially felt that may Pace freeview recorder was miles better than the cable box, but after about a week of viewing the difference is marginal.
    It's an inherent problem with plasmas unfortunately that they are far more unforgiving. The picture quality on my Loewe was far superior, but to be fair the digital picture quality is the best I have seen in a plasma display.
    Hope this helps
    Shye Wei
  4. gerry42
    gerry42
    Thanks for your reply. Have phoned Telewest who say that there is no setting changes to be made to their box regarding RGB etc.. What do you think?
    Gerry
  5. shyewei
    shyewei
    Dec 11, 2002
    4,784
    London
    +147
    Typical Telewest.
    If you press the telwest button (blue circles) then enter Settings -> Display you can adjust the output to RGB if it isn't already. Noticeably better PQ when set to RGB.
