Panasonic Viera 37PE30 - Does it accept 720p/1080i?
Discussion in 'Plasma TVs' started by Tejstar, May 15, 2005.
  1. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Just a quick question folks.
    Can the Panasonic TH37PE30 accept a 720p or 1080i signal (even though it will be scaled down)? There was talk of it not being able to even accept a 720p signal, is this true?
    I did a search and couldn't find a definitive answer. Thanks :)
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    It will be able to accept 720p/1080i albeit scale down to SD but it can't be referred to as "HD Ready" because of the lack of any HDMI/DVI connection and the fact that it wont display a minimum 720 vertical resolution.
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    If I remember correctly from all the multitude of posts on the subject a few months back...
    http://www.avforums.com/forums/showthread.php?t=142381&highlight=720p
    The PE30's will accept 1080i but will not accept 720p via component, as you mention the 1080i would be rescaled to the native res of 852x480. 720p just produces a black screen, I think. As I say I haven't experimented myself but did read all the posts regarding the 720p/1080i issue.
    The VGA input under the front flap will accept the following:
    640x480, 852x480, 800x600, 832x624, 1024x768, 1152x870, 1280x1024 & 1600x1200.
    S.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I think the VGA will accept others as well.
  5. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Ahh, I was just quoting the manual :) that had a big list of resolutions for the VGA connector.
    S.
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Well that's 2 conflicting responses already (from neilmcl and Steve P!) :D
    I know the VGA port can accept a number of resolutions but it was the component side of things I was most interested in.
    I was under the impression that Steve's opinion is correct (no 720p in component) - can anyone confirm this?
  7. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    I'm guessing that you missed MAW's comment and Scooby's comment in the link I posted? I get the feeling that these guys have first hand experience, I'd also trust Dutch's comments too. :)
    Tej, you could always give 720p & 1080i inputs a go a let us know for sure. ;) :devil:
    S.
  8. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    Tejstar, I was just speaking generally with regards to SD panels accepting HD signals, I didn't know that the PE30 had a specific problem with 720p. I don't have first-hand experience with the PE30 so Steve is probably correct.
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    :oops: I missed the link the first time around! :blush: Well that clears it up then!
    I just wanted to know as there's all this news regarding next-gen consoles (xbox 360 etc) and just wanted to know whether I'll have to upgrade my screen to display hi-def signals. And it looks like I'll have to... :(
  10. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    No worries mate. I was also under the impression that there should be no problem in displaying a 720p and 1080i signal (even though it would be a limited exercise on a sd screen).
    Why did the Viera have to be so quirky? :devil:
    Anyway, does anyone know if the new PV500 will support 720p & 1080i. I've heard rumours it doesn't support the latter? :confused:
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    on the HDMI input it will suport 1080i and 720p i would have thought via VGA too and can see no reason for not having the same on component, the PE50 and PV500 are very different beasts!
  12. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Ok cheers HD!
