panasonic video NV-SD220
Discussion in 'Digital TV & Video Players & Recorders' started by glanny18, Sep 14, 2005.
Tags:
  1. glanny18
    glanny18
    Which Remotes Will Work With This Vid? Please Anyone Help An Ignorant Person. Thanks
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +297
    Panasonic use several different IR freqs for their remotes. If your remote is faulty then you could try purchasing one of the multimodel remotes from Wilkinsons or other stores which come with a list giving the various codes used by different mnfrs.
    These lists are not always that accurate tho.
    Best bet is to purchase a learning remote (such as the Tevions for £4-99 - sold by Aldi two weeks ago) which you can then programme from the original. I used one of the latter for an LG TV (the codes listed did not include the correct code which was found by using the learning facility). Our nearby Aldi stores have now sold out of these remotes. I intend purchasing another when they are back in stock again). Handy items to have.
