panasonic Video board
Discussion in 'Panasonic TVs Forum' started by franc, Dec 8, 2002.
  1. franc
    franc
    Sep 12, 2002
    437
    Bucks
    +7
    Hi, just wondering if anyone has bought a tuner board for the series 5 panasonic plasma and no longer uses the video board which it replaces? Ideally I would like to try it in my Jap panasonic plasma which came with a tuner board only! Can you interchange the video board on the series 4 pannys too? I am unsure which series mine is. If anyone is local and has one I could try out it would be great. Does anyone know how much these are from the manufacturer?
    thanks franc
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,971
    Kent
    +314
    With the series 5 Pannys (e.g. my TH-50PHW5B TNR) the RCA Terminal Board (part TY-42TM4ZB) is an optional extra (if you buy the tuner model) and costs £80. It is no longer fitted as standard, and then swapped out with Tuner Terminal Board (TY-42TM5H).
    StooMonster
  3. franc
    franc
    Sep 12, 2002
    437
    Bucks
    +7
    thanks stoo, if anyone has a panny series 5 video board or is about to buy a panny plasma and doesnt want the board get in touch and i will take it instead.
    thanks
