Panasonic VGA to BNC - Any improvement?
Discussion in 'PC Gaming & Rigs' started by EmissarY, Sep 8, 2004.
  1. EmissarY
    EmissarY
    Hi all,
    I have a query of sorts. My pc monitor is a Panasonic PanaFlat PF70. I have had it since Sept 1998, when I bought my first P2 350 Intel machine.
    On the back it has 5 BNC connectors aswell as the vga connector. My question is whether or not I will get any improvement by buying a VGA to BNC lead as opposed to using the standard vga that I have been.
    My graphics card is an ATI 9800 Pro.
    Thanx for any input/advice,
    EmissarY
    :beer:
    P.S. Far Cry is the bomb!
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,550
    The Borders
    +3,025
    EmissatY
    You may get a sharper less nosier picture by replacing the 'as supplied' VGA cable for a higher quality/better screened cable - though I doubt VGA to BNC will be any different to VGA to VGA.
    Plenty advertisers on the AV Forums supply cables - we supply these if you want something high quality; http://www.bettercables.com/silservga.html
    Drop me a note if you want UK pricing.
    Best regards
    Joe
