Panasonic Veria Plasma - aspect ratio?
Discussion in 'Panasonic TVs Forum' started by Gary D, Apr 25, 2005.
  1. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    having bought my Veria last week (i'm mr happy!!) i have a question:
    why cant you change the aspect ratio when veiwing on componant inputs AV4C?
    i would mind this if it showed pictures in the correct aspect ration but it doesnt. movies etc are fine but 4:3 TV shows on DVD fill the screen.
    any comments or suggestions welcome.
    Gary
  2. mr_incredible
    mr_incredible
    Sounds odd to me? Ive got the 37PE50 and can switch the ratio around on AV4C, in some cases its necessary! Have you made sure the dvd player is set to 16:9 on the tv type in the setup menu? Other than that it sounds very strange. Might have to be a swift phone call to Panasonic!
  3. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    yeah all they settings are right (bought my first HC about 6 years ago so it should be right :D )
    i've called panasonic already and they told be that i cant change it. its not a great problem but it is a little annoying.
    Gary
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    If you watch interlaced signals via component then you will be able to change aspect ratios.
    If you watch progressive signals via component then the aspect ratio will be fixed to 'wide' and won't be changed.
    That's how the PE30's work, I presume the PE50's are the same.
    S.
