Panasonic UB820 or LG UBK90 for entry-level 4K TV?
watwhatt
I am looking to buy a new 4K UHD Blu-ray Player but kinda stuck on which one should I get between Panasonic UB820 or LG UBK90
My TV is 2018 LG 50UK6500 right now. Is HDR Optimizer in UB820 worth upgrading? (but anyway I am planning to get some OLED TV by the end of this year too)
Clem_Dye
Try the Panasonic UB450 or Sony X700. The LG machine, based on my experiences of it, is an utter mess. It's not even possible to disable CEC.
Zombie Twin
Get the Panny 820. It's a superb machine, which will bring out the best in any TV you put it with. I haven't had a disc yet which has caused it problems.
two2midnight
UB820
Jester1066
Another vote for the UB820 here. Very happy owner & well worth the extra money imo
AntBanks
820 definitely. I've had both too and love the 820, and as mentioned in one of my other comments on another thread, the upscaling is amazing.
Jester1066
Incidently I got mine from this company (via their eBay store). I paid the extra for the region free (DVD & Blu-ray) upgrade:
It's operated flawlessly since I got it. In the Panasonic range, only the UB9000 is better and even then, if you're connecting solely buy HDMI - there's no difference between them on a technical level.
The UB9000 has a better DAC (not relevant if connection is via HDMI), and has better build quality (metal chasis vs plastic). For most the UB820 is the one to get.
watwhatt
Hello again,
I ended up getting used UB320 from marketplace and i kinda impressed. At least 4K UHD performance is much better than my previous Xbox One X. Kinda disappoint that it doesn't have HDMI audio out port but I can connect it to my LG Atmos sound bar and passthough to my TV with no issue.
Also I like how Panasonic UI like more than LG player. Maybe if I get OLED, I will go for UB820.
