Panasonic U-73 error?
Discussion in 'Blu-ray & DVD Players & Recorders' started by vince_vega, Feb 5, 2009.
  1. vince_vega
    vince_vega
    Jul 29, 2004
    802
    28
    +26
    I have just taken delivery of my bd-30 but when i try to connect it up i get a u-73 error (which in the manual says hdmi problem or damaged cable) I am running it through a hdmi switchbox that is 1.3 compatible and i have no other hdmi issues with any of my other gear:mad:
    can anyone shed some light on this?
    p.s when i connect the player up to the socket on the tv it is fine!!:devil:
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,001
    Hi vince. :)
    That usually is the case yeah,the player doesn't like the switch box for some reason :( try having a fiddle,turn kit on in different order etc,apart from that not sure what else to suggest....sorry.
  3. vince_vega
    vince_vega
    Jul 29, 2004
    802
    28
    +26
    Thanks for the reply:thumbsup: I have sorted it now by using my plasmas dvi input!
  4. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
  5. vince_vega
    vince_vega
    Jul 29, 2004
    802
    28
    +26
    Everytime i try to update the player it says that the disc is incompatible!:mad:
    I don't know what im doing wrong as i am just downloading the update and then burning it to a disc using the windows vista cd burning feature........:lease:
  6. thenicklouse
    thenicklouse
    Oct 5, 2007
    379
    +31
    that is the problem i believe.
    try a different authoring tool.
  7. vince_vega
    vince_vega
    Jul 29, 2004
    802
    28
    +26
    can you recommend me a good one? just one with a free trial will do as i dont want to spend £50.00 on nero just to update my player ha ha ha :clap:
    my player has version 1.7 installed by the way
  8. vince_vega
    vince_vega
    Jul 29, 2004
    802
    28
    +26
    success!:thumbsup:
