Panasonic TYSTLOCAL1 Plasma Stand
Discussion in 'Panasonic TVs Forum' started by markevo, Oct 31, 2004.
  1. markevo
    markevo
    Aug 19, 2004
    32
    liverpool
    Hi All
    Just wanted to know if anybody knows if the panny pw7 will be fit on this stand ok. ?
    plasma stand
    thanks.
  2. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    It fits the PW6. I would think it would fit the PW7 as it is quite flexible on the attachement. It has moveable 2 arms which have a large horizontal hole to attach to the screen. Find out from one of the dealers if the fittings on the back of the PW7 are the same as the PW6.
    I did think that these stands were no longer made. I had enough trouble getting mine 6 months ago!
