Panasonic TXW32 Screen problem
Discussion in 'TVs' started by UKBOY, Jul 3, 2005.
Tags:
  1. UKBOY
    UKBOY
    Dec 2, 2003
    1,612
    63
    +176
    Been noticing a problem with images from all sources, whereby movement horizontally across the screen shows break up like horizontal lines on people walking and general movement across the screen.
    If you concentrate on one area of the screen and watch as an object moves across it, it seems as though every other line of resolution isnt keeping up with the others and appears almost as if the item is shimmering ?.
    Apologies for the poor description (always a bit of a strange one to describe a fault on a forum).
    Eliminated possible interference between scart and power cables and unplugged all but one item of kit and the same fault is exhibited with feed from dvd and from Sky Digital, so appears to be tv related.
    Any ideas folks ?.Anything in the service menu that I can try ?.
    Thanks.
    UKBoy.
  2. UKBOY
    UKBOY
    Dec 2, 2003
    1,612
    63
    +176
    Anyone ???????. :lease:
    UKBoy.
  3. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    check the scanning settings
    I have mine set to progressive or 75i whatever! I dont use 100hz at all
  4. UKBOY
    UKBOY
    Dec 2, 2003
    1,612
    63
    +176
    Its a 50HZ only set.
    Any other thoughts ?.
    UKBoy.
