Question Panasonic Txl37s10b set to HDMI on startup
Discussion in 'Panasonic TVs Forum' started by spenn, Jun 10, 2015.
  1. spenn
    spenn
    May 19, 2015
    24
    London
    Hi Hope someone can help me.
    I have Marantz NR1602 AVR, KEF 2005 speaker, Panasonic BDT130 Blu Ray and Panasonic TV as above. All connected via HDMI
    How can I set the TV to automatically default to HDMI on start-up. It goes straight to Analogue with a fuzzy screen which then has to be changed by remote.
    Any ideas???
    Many thanks
    Steve
  2. MW55
    MW55
    May 13, 2014
    102
    +7
  3. spenn
    spenn
    May 19, 2015
    24
    London
    I tried the set up menu but it still defaults to Analogue.
    Thanks for your comment...appreciated
  4. MW55
    MW55
    May 13, 2014
    102
    +7
    Do you have the model number of your Panasonic TV?
  5. spenn
    spenn
    May 19, 2015
    24
    London
    Yes, as above in the title it is a Txl37s10b
  6. MW55
    MW55
    May 13, 2014
    102
    +7
    Oops!
    I was trying to get the manual for this to see if it helps but I can't get PDF files working at present.
    Take a look at:
    Panasonic Terms of Use
    and see if that helps.
    Failing that can always try the Hotel menu option but be **VERY** careful as it would be easy to mess up the settings for the TV making it not work as before.
  7. spenn
    spenn
    May 19, 2015
    24
    London
    Hi Tried the manual. Apparently only works if you use a Scart cable. Will just have to manually change
    . Thanks anyway Best Steve
  8. JayCee
    JayCee
    Jan 20, 2004
    24,000
    Lanarkshire
    +2,617
    No, as long as you use the HDMI1 input it will work with HDMI.
  9. spenn
    spenn
    May 19, 2015
    24
    London
    Thanks....
