Panasonic TX36PL32
Discussion in 'Panasonic TVs Forum' started by taryn p, Oct 24, 2004.
Tags:
  1. taryn p
    taryn p
    Hi there,
    I hope someone can help. I'm trying to work out the multi window option on the above TV. I've followed the intructions in the manual, but for some reason, it will only display the same channel in both windows. It says to press the multi window button to select between picture in/out of/and picture, then press the green button until you get to the current channel, and from there you can use the remote to change the channel of the right window.
    For some reason though, whatever I change the right window to, the left also changes to that aswell.
    Can anyone figure out what's going wrong? Thanks for any help.
    Taryn
