Panasonic TX36PL30
Discussion in 'TVs' started by dragon77, May 26, 2003.
Tags:
  1. dragon77
    dragon77
    I was thinking of buying the Panasonic TX36PL30 36" WS TV
    as one retailer is selling it for a very low price of £868 + delivery :eek:
    Has anyone had problems with it ?
    Is a 36" TV still ok to watch broadcast TV and video ?
  2. IanRidley
    IanRidley
    May 26, 2003
    12
    Consett
    Which retailer has them for this price?
    Ian
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    dragon77 try searching for it by model no or Panasonic 36" it has been discussed loads in the past!!! As have all 36" sets!
  4. dragon77
    dragon77
    I have used the search button but wanted some recent views :clown:
    Pm u Ian
  5. shaunthedude
    shaunthedude
    I had this tv for about 6 months. Great set apart from a vertical bar that was visible on bright backgrounds. The bar was about 6 inches in from the left. ALSO, when watching reg 1 dvds there was the MOIRE effect. VERY annoying. Thats the reason i got rid of it. If you are not using it for reg 1 dvds go for it
    hth
    shaun
  6. Jpfahy
    Jpfahy
    Empire Direct or QED are doing these cheap
