Panasonic TX32PK2 work in Holland?
Discussion in 'TVs' started by mfacey, Sep 2, 2005.
Tags:
  1. mfacey
    mfacey
    Does anybody know whether the Panasonic TX32PK2 works outside of the UK? I have one available to me which was bought in the UK. But seeing as the UK uses a different system I'm worried it won't work in the rest of Europe. Anybody know?
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    It really depends which version of that model it is. If it has the right suffix for Holland then it will. But since it was purchased in the UK it probably wouldn't work with analogue terrestrial or cable. You should be OK with pay-TV from a Dutch-market set-top box through the scart though.
