Panasonic TX32PD50C or Toshiba 32ZP48P
Discussion in 'General TV Discussions Forum' started by chrisw112, Jan 12, 2005.
Tags:
  1. chrisw112
    chrisw112
    May 30, 2004
    22
    I have narrowed my search for a new 32" TV to the new Panasonic TX32PD50C or Toshiba 32ZP48P.
    I particularly like the Panasonic but a bit worried that the problems of its precedessor might be present in the new one.
    I like the Toshiba, but as I already have an external sound system, I don't need one built into the TV, but will go for the Tosh if the Panasonic TX32PD50C has similar problem to the previous one.
    Comments please.
  2. Bulldog-Dazza
    Bulldog-Dazza
  3. JohnW14
    JohnW14
    Aug 6, 2004
    77
    Wiltshire
    Chris
    Have you considered the Tosh ZP46? Same as ZP48 but with only NICAM sound. Only available from Currys/Comet I understand, but may suit you perfectly.
  4. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    I bought pd50 2months ago and still no problem.
    more and more people are claiming the above.
  5. Brainboy
    Brainboy
    Jan 5, 2005
    88
    Aberdeen
    Anyone who has one know if you can switch of the 100Hz processing on either the TX32PD50C or the alternatives suggested on this thread to get a 50Hz picture for watching football?
  6. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Apart from 100 htz,the panasonic uses actuity which is compromise between 100 and 50htz.They dont have a true 50htz scanning mode.
  7. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    I think there is a 75Hz option on the PD50, at least there is on the 36" version.
    S.
  8. BernieC
    BernieC
    Interesting - and good news re picture quality on the Tosh. I have a 36zp46 and am VERY pleased! There are four scanning settings which are geared for normal viewing / movies & fast action / sport / dvd ... pls see following link.
    www.home-entertainment.toshiba.co.uk/consumer/home.nsf/pages/whatis-pf3-trueimage?opendocument
    Whilst 3 of the modes scan at 100Hz the progressive works at 50Hz horizontally with equiv to 100Hz vertically.
    There is also Component Video Input which allows for best quality connection if your dvd player has CV output.
    The Nicam sound that is built into the set is also fine for normal viewing and comes complete with sub-woffer control from the remote...
    Hope this helps.
