panasonic tx32pd30 or toshiba 32zp38
Discussion in 'General TV Discussions Forum' started by miskin83, Jun 8, 2004.
Tags:
  1. miskin83
    miskin83
    please help
    which one to purchase the panasonic tx32pd30 or toshiba 32zp38?
    or should I go for a different TV all together (£1000.00 to spend)
    can someone explain the 50hz progressive scan on the panasonic.
    thanks
    anth
  2. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    i can't say anything about the panasonic tv because i don't have one, however i do have a 36zp38 and i think its amazing! i don't think pictures will be that different between the two sets but with the toshiba you get dolby digital surround.
    the sound and pictures are superb (especially on dvd through component cable) and i would reccommend this tv to everyone.
    i know people have had faults with both toshiba and panasonic tv's but mine is fine.
    both tv's also look very cool but i prefer the look of the tosh.
  3. Puneet
    Puneet
    go with the toshiba mate, i spent like 10 days reading forums up the ying yang and the toshiba came off better in picture and sound, then there's the fact that it looks bloody nice too. And read the huge thread about PD30 problems!
    The cheapest place you're gonna get it for now is sound & vision online, JL are out of stock and don't even know if they're getting stock in...ever? (that's according to 4 different JL stores)
  4. paul710
    paul710
    Feb 16, 2004
    34
    Bolton
    Had my TX36PD30 for 6 months now and I am very pleased with it. Seems that I have been lucky to get a good one - but I had to go into the service menu to fix a few faults - geometry, overscan and the position of the picture all needed adjusting. I've also found using the DVE disc helpful in tweaking the brightness, colour etc. After doing all this I think it's the best picture of any CRT I've seen.
