Panasonic TX32LXD70 picture quality
Discussion in 'Panasonic TVs Forum' started by spluff, Sep 21, 2007.
  1. spluff
    spluff
    Oct 23, 2006
    228
    +5
    Hi all,
    I have just bought this and me and my wife are completely underwhelmed with the picture quality............
    We owned a 32" Sony CRT for years and the picture quality was great.
    With this TV it dont look very good on Freeview. Was the worst last night on Channel 5 trying to watch the football......
    Hooked my PS3 and it looked fine though.......
    What is causing the poor picture quality on freeview? I always thought our signal reception was fine (although it is a joint arial).
    What are good settings? Ive tried changing things........
    Could we have a duff tv?
  2. snaithg
    snaithg
    Apr 7, 2006
    3,187
    +623
    Try this thread!
    http://www.avforums.com/forums/showthread.php?t=491586
    Graham.
  3. chrissyman
    chrissyman
    May 1, 2006
    418
    28
    +33
    Try turning off all advanced settings, contrast down /sharpness etc,also is it set to live or vivid as default if so switch to standard.
    Generally have a play with settings you should be able to get decent picture,
    i had Sony Crt and now have a Bravia lcd and was getting similar results to yours,but now after tweaking the settings its very good' maybe not quite as good as my old Vega but i am happy with it.
    I hope this helps.
