Panasonic TX32LXD52
scoobysnax2
:confused: Hi
Im new to this so bear with me! Im waiting on the new Xvox and want a hi def flatscreen lcd to play it on, watch dvds and tv. Been consdiering the above tv seems to have good reviews (better then the samsung le3252bdx).
Seems the response rate is 12ms, anyone got one and happy with its perforamnce in games, dvd and general tv?
Thanks for your help!
:lease:
PhilipL
The panel in the Panasonic is from Samsung and they rate it at 8ms.
I have seen nothing that suggests there is any problem with response rates, the picture is excellent with no blurring.
Regards
Philip
po_man
PhilipL said:
Regards
Philip
I was under the impression that Panasonic, along with Samsung, LG/Philips, Sharp make their own panels? Are you sure it's not some other part/component that's made by Samsung?
Trending threads
Trending threads
