Panasonic TX32LXD52 - Wall brackets???
jpk2112
Anybody know where I can buy a wall bracket for a Panasonic TX32LXD52 .
With the back on the LCD not being flat I've been told that getting one may be quite hard, so any information would be much appeciated.
jpdsam
Hello,
Could anyone tell me if this screen is VESA mountable? I've got one on the way to me and need to get a wall bracket for one.
One of the shops where I enquired about a bracket got back to me asking if the TX32LXD52 was "VESA" mountable - they said I could measure the hole spacing to find out, but as I haven't got TV yet, this would be difficult!
Cheers in advance
bledd
I've bought a 32lxd500, which has the same whole pattern as the 52, for simplicity and less hassle i opted for panasonic's own bracket which i bought direct from them for £99.99 Here's the link :thumbsup:
F
Flame
I have a TX32LXD52 and I bought a PLB1 wall mount bracket from SellTel via Ebay.
I had to cut the bracket down to size (bit of a pain in the ass), but it works well and more importantly it feels very solid.
Not bad for £54.
worldpeace
I have a Vogels 2004 wall bracket, and all was ok. The only problem that I found was when it came to connecting the cables to sockets on the back of the tv. In the end had to get two other people holding the set in a horizontal position and for me to be on a ladder to plug them in as my cables are in the wall. This is my install, see pictures. Just to note that the power cable going down the wall is only there until I have further tested the screen then I will cut it and connect it to the wire I have buried in the wall. Hope this will help others.
And yes this is the lxd500, but as previously said, it has the same back as the 52
RICK67
Does the bracket have a tilt function ?
san_marco
I have the same screen and also looking to wall mount like yours. How big a hole do you have for all the wires to come out of? Are the wires chased into the wall? Can you show pictures of where your other equipment are and your aerial lead and plug sockets are?
worldpeace
Who is this aimed at?
worldpeace
san_marco said:
Yourself worldpeace
Okay what I did was totaly decorate the room in one go so as you can see from the photos, yes indeed the wall was chased out to allow me to bury trunking into the wall, thus placing a mega amount of wires into it. I also got a piece of wood and done the same, but glued and screwed this to the wall?, this was done to get better/stronger fixings for the wall bracket. And then it was plastered. Cant be bothered to take a photo of my equipment unit, but that about sums up what you was after.
After-all you must use your own imagination.
geeWcee
Worldpeace, if one of the cables develops a fault, how do you go about replacing it? How do you feed it back thru the cable trunking?
worldpeace
Hope no one would ask that question! but the answer is you cant, once it's done that's it.
I was well aware of this problem before and while doing this project, I had many thoughts on how to overcome this problem but had to make a choice and go with what I thought would be the best looking finish.
1, I could have battened the wall out and put plasterboard on-top, then the wires would have run loose behind.
2, Could have surface run the wires, then put them in trunking to hide.
3, Not bothered, and sat the TV on a unit/desk.
I wanted a clean clinical finish, so I did what I did and took the risk. The cables were fully tested before placing in the wall, and I put more than needed cables in the wall in case one did become faulty, 3 Scarts, 1 HDMI , 1 VGA, 1 Arial lead, 1 Audio L+R, and a component to top it off. £400 in total.
Sorry for the long winded reply.
geeWcee
no problem. Thanks for taking the time to reply. Good idea putting in more cables than you need, for backup.
marcstang
Where did you get the Vogel 2004 bracket from ? I've been looking in a few places but can't seem to find anyone who sells them at a decent price.
P
Pardsme
I'm too looking at this model:
Vogel’s : EFW6325
Anyone? :lease:
I presume this model can extend out and move from side to side.
Can someone tell me what the point of having a tilt function for lcd brackets?
marcstang
The tilt function allows you to tilt the screen downwards if mounted high for better viewing. some backets also tilt up to allow access for cables and connectors. I'm mounting my screen quiet high (150cm) so tilt down is essential for good viewing from my seating position.
J
_Jon
Vogel’s : EFW6325
Anyone? :lease:
I was going to go for that model but gf freaked out when she saw the price. I explained you cant use a £35 Argos kit for a panny:)
Accident Man
If anyone can advise on the following please?
What size screws are needed to connect a wall bracket to the TX32LXD52?? I just received the FAPA-01 adaptor to use with a Vogels EFW2001 but the supplied screw/bolt things are too big for the holes on the back of the panel.
Latest News
What's new on Netflix (UK) for October 2022
  • By Ian Collen
  • Published
Starzplay streaming service rebrands as Lionsgate+
  • By Andy Bassett
  • Published
JVC adds Filmmaker Mode to latest D-ILA projector firmware
  • By Andy Bassett
  • Published
Bowers & Wilkins launches Px8 headphone
  • By Andy Bassett
  • Published
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
