Panasonic TX32LXD500 or Hitachi 32LD7200
Discussion in 'Panasonic TVs Forum' started by daxie, Jul 14, 2005.
  1. daxie
    daxie
    Jul 9, 2005
    242
    16
    I can't really decide between the two...
    They both tend to get great reviews...
    The panny seems to bit better connection-wise, has some connections on the front, which the hitachi seems to be lacking.
    But the hitachi has dvi AND hdmi, and the panny seems to be missing regular D-SUB, or am I wrong?
    Viewing will be mainly analog cable (Belgium), and xbox using upscaled 720p. Later on will probably add digital tv through RGB-scart.
    Please help me make a decision... (almost desperate here)
    daxie
  2. bishman
    bishman
    Mar 29, 2001
    4,902
    83
    hertford
    +172
    I also face the same decision.
    Mines for the bedroom, replacing a 28" Sony widescreen CRT and is going to be used mainly for DVD viewing and also with an Xbox and later a 360 and PS3. TV is viewed on it for less than 1% of the time it's on and is from an analogue cable source, so TV performance is pretty much not an issue for me.
    Need hi-def for 360, PS3 and later, HDDVD/Blu-Ray.
  3. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    I two have been looking and reading all the reviews for both sets :smashin:
    Both are top notch 32" lcds buy the sounds of it ,
    The Panny has better Contrast but will cost about £500 more than the Hitachi also has very good connections and looks better if you ask me but word here is the Hitachi buzzing can be a bit loud ,
    Which one do you buy :confused:
  4. Drifty
    Drifty
    Jun 14, 2005
    105
    16
    I in the same boat too, but I'm waiting to see a review of the LG 32LP1 (due v.soon) and the new Sony V series (Local Sony Center quoted October)
    I'm not too worried about the money (ie: Sony) - I just want to take in all the info and make an informed choice.
  5. daxie
    daxie
    Jul 9, 2005
    242
    16
    drifty, the longer you wait, the harder the choice gets...
  6. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Tell me about it , but the prices will hopfully come down a wee bit
    :D
  7. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    Why not check out the jvc 32" 6 series? It has no buzz, is a lot cheaper and has an amazing picture on dvd's and a good analogue tuner build in (i live in the netherlands and the picture from cable is good for a lcd, not better than crt or plasma though, gotta get digital for that) and besides that it's got all the connections you could wish except dvi.
  8. alefsin
    alefsin
    Feb 15, 2005
    130
    I have a Hitachi 32LD7200. No buzzing here. About the connections, it does not have anyting in front, but it has got a S-VIDEO and comosite + audio connections on the side.
  9. Drifty
    Drifty
    Jun 14, 2005
    105
    16
    true true - :rotfl:
  10. MilesR
    MilesR
    I have the Panasonic TX32LXD500 - absolutely chuffed to bits with it
    The digital tuner provides a top quality picture. HDMI, VGA, component, 2xRGBscart + 1 normal Scart, composite & S-video inputs. (The normal scart also provides DVB output I believe).
