Panasonic TX32LXD500 Cable help
Discussion in 'Cables & Switches' started by blp21, Sep 2, 2005.
  1. blp21
    blp21
    I am in the process of buying the Panasonic TX32LXD500 LCD TV and a dvd player and dvd recorder and i want to connect the recorder by component and the player has a dvi connection so i will be using an adapter to connect it to my hdmi slot, according to the manual if i use a adapter to connect a dvi device to my hdmi connection and will also need to connect audio cables and i will need to connect audio cables for the dvd recorder component connection and as far as i can tell there is only room for one set of audio cables, from the manual i cannot find any Coaxial or digital connection on the tv so i cannot figure out a way to connect both please help it will probaly be a simple solution but i do not know it.
  2. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    5,985
    2
    2
    Bromsgrove
    +584
    Hmm, a tough one...
    You could use some Y Cable splitters for the input, but that is obviously a far from ideal situation!
  3. blp21
    blp21
    thanks for the idea but any other solutions
