Panasonic TX32DTX11 problem
Discussion in 'Televisions' started by Wingnut_72, Jul 31, 2005.
Tags:
  1. Wingnut_72
    Wingnut_72
    I received delivery of a new Panasonic TX32DTX11 on Fri 29 July.
    On Saturday night the TV intermittently started switching off then on again, six times in 2 hours altogether.
    Also the screen looks dirty behind the anti glare screen.
    I presume these problems are faults. Could anyone advise me on this before I contact the retailer.
  2. JayCee
    JayCee
    Jan 20, 2004
    20,070
    Lanarkshire
    +1,912
    What's to advise.............you have a very obvious fault and need to contact where you bought it from. :confused:
  3. tools
    tools
    I've been told theres a few software problems with the 28" and 32" models
  4. The Fiend
    The Fiend
    Nov 5, 2003
    131
    +9
    A software problem? If so how do we go about getting the software updated?
  5. tools
    tools
    The company that I brought the set from are taking the set away to sort out the software problem and a tube problem I have. All they told me was that some of the 28" and 32" panasonic tvs have a software problem with the freeview my 28" when I first got the tv it kept turning off and on. In the end I pulled the ariel out because I have cable and didn't mind not having freeview. Then a dot appeared on my tv screen and I called an engineer out. So I mentioned the switching off and on that the tv does when the ariel is connected thats when he mentioned a software problem with some of the 28" and 32" if you have a problem like this get in touch with the company you brought the set from and they should sort it out.
