Panasonic TX32DK20 vs Philips 8707
Discussion in 'Televisions' started by Drefuzz, Jul 25, 2003.
  1. Drefuzz
    Drefuzz
    After my Salora 28 inch widescreen died on me last week, I started to search for a new set. I ended up finding two possibilities, the Panasonic TX32DK20 and a Philips 8707, both at 6000 dkr (500 £, 800 euro). The Panasonic isn't in the UK catalogue. It's a 100 hz 32 inch non-flat Quintrix. The 8707 is similar to the 8717.
    Any ideas? It's been more or less impossible to find reviews on the Panasonic, but the Pannys seem to fare ok in tests...
    Regards,
    Niels D
