panasonic TX28Pm11 OR ANOTHER?
Discussion in 'General TV Discussions Forum' started by Stinky985, Aug 26, 2004.
Tags:
  1. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    I need a new TV and dont have much cash i want it to last a couple of years until LCD/Plasma prices come down more.
    A couple of questions if i may.
    1. Why do people say 100Hz isnt worth it on a 28" tv?
    2. Is the TX28Pm11 ok - it seems cheapish at C**et at the moment, and reviews are scarce. Also, does the kit fit on the shelves of the stand?! (iwould need dvd+receiver on one shelf could it handle that?)
    3. Would i be better off with a 50Hz set either IDTV or not (can always get a freeview box later, ideally with digital out which IDTVs dont seem to have.) Was thiniking of Panny/ sony IDTV's around £500
    4. Will be getting Sony DVP NS930 (or similar quality) to chuck the DVDs into it.
    For reference, i had DVP NS900 and Panny TX28 PL1 and thought that was a great picture. Looked good on Sky too. i dont have them anymore so need to 'start again' relatively cheaply.
    Any advice appreciated.
