Panasonic TX28pl1 glass shelf for stand?
Discussion in 'General TV Discussions Forum' started by tall.small, Nov 9, 2004.
Tags:
  1. tall.small
    tall.small
    Oct 4, 2002
    88
    Kings Lynn, Norfolk
    Just wondering if anyone knows of where to get an extra shelf for the stand from, mine only has one and I could really do with another.
    Have tried Panasonic UK but they seem really expensive, over £50 for the glass shelf and fittings.
    Is there anywhere else that I could try?
  2. KopiteLad
    KopiteLad
    If you look in yellow pages for "Glass Merchants/Manufacturers" they should be able to cut you a piece identical if you give them the measurements, or pop in and see them with your 1 remaining shelf. :smashin:
  3. tall.small
    tall.small
    Oct 4, 2002
    88
    Kings Lynn, Norfolk
    excellent, cheers for the advice, hadn't thought of that!
