Panasonic TX28DTX1 advice
Discussion in 'General TV Discussions Forum' started by cruedude, Aug 26, 2004.
Tags:
  1. cruedude
    cruedude
    Can anyone give me advice on the following problem please
    I have recently purchased a 28" Panasonic Widescreen TV (model TX28DTX1) and I have problems when trying to use a DVD player on it.
    When I play DVD's on it through any of the AV sockets (Scart and RGB) the bottom half of the screen is much brighter than the top, it's particularly noticeble when watching darker scenes.
    At first I thought it could be my DVD player but I have tried 3 different ones with the same effect, funnily enough though I do not have this problem when connecting a satellite receiver or VCR to these ports, only with DVD signals.
    Has anyone else had this problem or can give me any advice?
