Panasonic TX28DK1 service menu
Discussion in 'General TV Discussions Forum' started by Jimmi, Apr 13, 2003.
Tags:
  1. Jimmi
    Jimmi
    Sep 8, 2002
    501
    28
    +29
    Could anyone point me in the direction of the service menu for this set please ?.
  2. Jimmi
    Jimmi
    Sep 8, 2002
    501
    28
    +29
    anyone ?.
  3. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    Most recent Panasonic TV's enter the service mode like this:
    Turn BASS to MAXIMUM
    Turn TREBLE to MINIMUM
    Press -/V button on the FRONT of the TV control panel WHILE pressing the INDEX button on the remote.
    This should bring you into the service mode.
    Now use RED or GREEN to go up or down thru menu options
    and use YELLOW / BLUE to increase / decrease
    Press STR to store your change
    You must store each change one at a time, so eg.. alter the height then STR, then alter the width then STR etc...
    Turn off and on again to exit menu
    BE CAREFUL WHAT YOU ALTER... DON'T PRESS STR UNLESS YOU'RE SURE YOU WANT TO STORE THE NEW SETTING!
    make notes of each setting before you alter it! the TV service mode will be in 16/9 widescreen mode only - you can't alter settings per aspect ratio so get a compromise for ALL aspect ratios.
