Panasonic TX28CK2 Geometry Problem
Discussion in 'General TV Discussions Forum' started by schakera, May 8, 2005.
Tags:
  1. schakera
    schakera
    Hello,
    I have just purchased a Panasonic TX28CK2 and the geometry is incorrect, the image slants more on right of the screen (rather annoying).
    Does anyone have any advice or a way to get into a service menu of this television, or would I have to call out an engineer to fix this?
    thanks....
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    schakera,
    Not a good idea to mess around in service menu's unless you really know what you're doing.
    Search through AV Forums and you'll find the horror stories of those who didn't. :D :devil:
    I for one am not in favour of posting this type of information, certainly on here.
    I wonder where AV Forums would stand if someone decided to take action after screwing up their TV from bad advice on the forums? :eek:
    If it helps, there is a picture 'rotation' in the set up menu on the 28CK2. Does that help? If not - I think you should call an engineer. Sorry.
    Again, if it helps, the set is a EURO4 chassis. :)
    A. Dork
  3. schakera
    schakera
    Thanks Arthur for your advice, however I could not find the picture rotation feature in the setup menu. Please advice...
    thanks,
    schakera
