Panasonic TX26LXD52
Discussion in 'Panasonic TVs Forum' started by neidpath, Oct 22, 2005.
  1. neidpath
    neidpath
    Jul 5, 2005
    5
    I am a newbie and so my questions no doubt will seem quite naive, but I would be greatful for some advice.
    I have bought and am awaiting delivery of a Panasonic TX26LXD52 LCD hight definition ready TV. I also have a Panasonic DMR-E55EB DVD recorder.
    Up till now I have been using fairly cheap standard Scart cables and I wonder if it would be worth while investing in more expensive and (hopefully) superior cables. Would it make a difference if I did upgrade.
    My second question concerns another connection. Both units have Component Video connections and I read that to have the optimum quality when playing DVDs I should invest in a suitable cable. Again, can anyone advise if this is so, and if it is, is the Component video connection in addition to the scart connection.
    I hope this makes sense. Would be grateful for any help.
    Neidpath
  2. Sicton
    Sicton
    Jul 26, 2003
    190
    Bristol, UK
    If you've got component, forget SCART because component is much, much better quality. Don't bother buying expensive SCART cables, just invest in some quality component leads and you'll get the most out of the two pieces of equipment.
  3. neidpath
    neidpath
    Jul 5, 2005
    5
    Thank you very much for quick response. Very helpful.
    One other question though. Will the component leads also carry the audio signal, or does that need another connection?
    Regards
    Neidpath
  4. Sicton
    Sicton
    Jul 26, 2003
    190
    Bristol, UK
    Component only carries video signal - it splits it up into components of red, green and blue. A separate cable is required for audio. Do you have a home cinema amp the DVD player could be connected to for the audio?
  5. neidpath
    neidpath
    Jul 5, 2005
    5
    Thanks again for response.
    No - I am afraid I don't have a home cinema set up. Can I connect audio direct from the DVD player to the TV?
    Neidpath
  6. Sicton
    Sicton
    Jul 26, 2003
    190
    Bristol, UK
    It's not something I've ever done because I've never had the privillage of owning anything with component inputs/outputs, but I'm pretty sure that would be possible if you've got audio inputs on your TV i.e. phone - red/white connections!
  7. Jonti
    Jonti
  8. RedFrog
    RedFrog
    Apr 19, 2005
    17
    I think the audio inputs for the TX326LXD52 are on the front though (going by panasonics website) so if trailing cables bother you it might not be your best option.
    BTW can anyone who's got one of these confirm this?
  9. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    LXD52 has an HDMI terminal, the best quality signal willbe via an HDMI cable.
  10. Jonti
    Jonti
    The audio-in sockets for Component are on the back. It's the audio-in sockets for S-Video that are on the front (AV3). (Page 40 of the manual)
  11. RedFrog
    RedFrog
    Apr 19, 2005
    17
    Thanks for that Jonti, Panasonic's site here seems to claim the audio in for s-video and component are both on the front with the sockets on the rear being audio out only which was the one thing putting me off buying this set.
    I've not seen the manual but if explicitly states they are component inputs on the rear then I'm a happy man :thumbsup:
  12. Jonti
    Jonti
    I know what you mean - I was concerned about that as well so I had to check in John Lewis on the 32" models. The Panny 500 also has the same setup - 4 scarts: 3 x on the rear (AV1/2/4), 1 x on the front (AV3).
