Panasonic TX22LT3 Service Menu?
Discussion in 'Panasonic TVs Forum' started by image165, Sep 30, 2004.
  1. image165
    Sep 30, 2004
    145
    +3
    Does anyone know how to access the Service Menu on a Panasonic TX22LT3? I'm assuming it has one. I'd like to tinker with the horizontal positioning of the image on the screen.
  2. image165
    Sep 30, 2004
    145
    +3
    I know it's a bit sad to be replying to my own post, but I figured out how to get into the Service Menu on the Panasonic TX22LT3. Here's what you do:
    - Set the Bass to maximum
    - Set the Treble to minimum
    - Press the down button (-/v) on the top of the TV, and press the Index button on the remote, both at the same time
    - The Serivce Menu should appear on screen
    - Press the red/green buttons on the remote to step up and down through the functions
    - Press the yellow/blue buttons on the remote to alter function values
    - Press the STR button on the remote after each adjustment has been made, to store the required values
